Windows Thunderbird 139.0 (64-bit): Embed Link fails with advanced options (bug1969767)
The 13x version appears to have introduced a bug.
When pasting links into emails, and then "inserting" the link, if you try to add any advanced options to the link (i.e. target=_blank), it doesn't create the link.
If you simply "insert" the link without setting any advanced options, then the link is created.
เปลี่ยนแปลงโดย Wayne Mery เมื่อ
การตอบกลับทั้งหมด (2)
Nicely put. I agree. Can you file a bug report? https://bugzilla.mozilla.org/enter_bug.cgi?product=thunderbird
